Hi!
Could someone post a pic of the grey ecu/ecm coneccting from a california type 929rr, need to know to which pin the Orange/White wire goes?
Got a european model but apperantly someone changed the ecu/ecm to a cali type and now the 23 fault code is on, wiring harness dosent have the o2 sensor connection so I need put the resistor straight to the ecu, just dont know to what pin the other end needs to be put!
Hope someone can help...
