1 - 2 of 2 Posts
I just recently put it on and i guess it wasnt tight enough...the bracket that goes on the tree of the handle bars has that little pin sticking out that goes in the slot..well mine broke in 2..can i just go buy a steel rod and put it in the hole and go from there? I dont wanna have to an entire new bracket. Thanks.
is it just a little pin that snapped in half and there is a hole in the bracket you can put a pin in there ? cause if so, that wourld work, but im not sure the hardness of the pin. if you get something too hard, it could damage the bracket and tree.. so it's adviseable that you order one from ohlins, but if push comes to shove, finding a pin that fits will get you back on the road wtih a damper.
1 - 2 of 2 Posts
