1 - 2 of 2 Posts
On an Ohlins rear to adjust ride height do you have to detach the lower mount in order to spin the clevis like like the manual says or can you just loosen the lock nut and turn the other one to adjust the height?
RRWANTR : On an Ohlins rear to adjust ride height do you have to detach the lower mount in order to spin the clevis like like the manual says or can you just loosen the lock nut and turn the other one to adjust the height?
Just loosen the lock nut--but you need a huge--either 25mm or 24mm (ill have to check wrench)--I thought the same thing--until I started adjusting it on the bike
1 - 2 of 2 Posts
