I can't seem to figure out how to remove the bulbs from the indicator lights on my 94 honda CB1K. I have the speedometer taken apart to change the bulbs and they are down inside a rubber socket that isn't very flexable. Any tips on getting them out? I've tried "rolling" the rubber down and it gets closer but still not possible with my fingers. Is there a tool for this? Needle nose pliers? Seems like I'd shatter the bulb or rip out the wiring if I get too rough with it. Help.
If all else fails, you could try with the pliers and if it shatters just pull the rest of the base out.
Is there no way you could get a set of tweezers down there?
