on the road, need info from service manual
1 reading
1.3K views 3 replies 3 participants last post by  BushrodW
#1 ·
The error light on my 929 is flashing 3 longs and 5 shorts.
Could someone please look in their svc manual and tell me what 3,5 is telling me?
Please and Thanks in Advance
BW
#2 ·
If codes interchange between the 929 and the 954, this may be of some help.
The 954 code indicates a faulty EGCV and air intake valve servo motor. The manual starts by having all wire connections checked. Engine still runs as default safety. The 954 manual shows this to be located on the left side behind the engine, so check all the wire connections in that area. Perhaps the 929 is similarly arranged.
Hopefully someone with the 929 manual will chime in soon. For now, checking wire connections won't hurt no matter what model bike.
Good luck.
#4 ·
Thanks You....
Thanks Max and Red Rider :highclap::highclap::highclap:....
That makes sense, as the low end is feeling somewhat off her feed.
Again, I really appreciate the time you took to do the posts.
fireblades dot org does rock.
Sitting by a pool in Redding, CA and tomorrow to return back to cold and soggy Oregon,
Bushrod
