there are two types of vfr swing arms meaning the shock+ linkage is mounted in
in different locations on the swing arm.check the vfr forums they might can help you out. i am using a honda superhawk swing arm on my 88 huricane 600.
Its all in the measurements so check the length of yours from the pivot centre to centre of the rear axle slot and the width of it at the pivot from left to right.
Once you have this info you need to go checking around as to which ones have the closest dimensions to your swing-arm figures.
