Hello guys my 400rr nc29 has a Fireblade front end and I have designed fronk fork sliders for it, they are an exact fit and will be held together by a 1/2" 13mm stainless threaded rod made to suit and two M8 high tensile bolts lengths to determined when I take the wheel off, but I will post details of this later. I know the drawing is quite detailed but imo if you want it to be right then make it right. I am still working on the frame mounted Bobbins but these will be for the 400rr nc29.
Please if you see any problems let me know before I start to machine these.
Any questions feel free to ask away.
FYI right hand drawing is front axle bolt side
Thanks Mark
Thanks Mark
They look good, way over-designed though in my opinion :)
I have skateboard wheels on my GSXR750, on a simple length of M8 threaded rod :)
I know they are over designed but I am a bit of a perfectionist and for me "bestest" is best :thumb:
What's your reason for the plastic, why not just make them from aluminium?
The Acetal co-polymer is very strong but slippy, and you can make a few because its really easy to machine and then you keep the strong internal plug intact and just change the sacrificial outer if you have an oopsy :D
