Tried to find th epair valve mod write up, but it seems that it wasn't carried over from the old site...
Conq? Is it still floating somewhere?
Z...
I personally will not do the mod. I really think it's not going to give you the hp gains.
Would be worth the time and energy spent?
Thanks everyone.
I should still block it off for the AF mixture dyno runs- right?
I cannot see how it would be accurate otherwise.
Yes you will need to block it while getting the air fuel readings on the dyno, the operator should know this and probably just pinch them closed
