It was wrecked and i'm parting it out. Not enough money to fix'er up. Fairings are toast same with the lamps, gauges, clipons, rear tail skeleton is bent maybe fixable, clutch lever assembly, front rim and tire, wiring harness is okay shape i fixed some wires. Motor cranks over fine no spark needs new wire in cyl 4 odo had 16,xxx miles or so. has upgraded headers too, radiator a little banged up but will works.
Inner fairings toast?? How much for ign switch, fuel cap setup and trunk lock with keys?? How is rear seat itself??
rear seat toast, the trunk lock its non existant and when i bought the bike the key for the ignition was pretty much worn out.
ok. What about the inner fairings. I assume toast?? Both rear plastics shot?? How much for complete carb setup? How are the tires??
