1 - 20 of 37 Posts
I will be picking up a parts bike this Tuesday. I am only keeping the frame, motor, carbs, shock, subframe and harness.
For sale:
16" black front rim & tire, black plasti-dip
Front rotors
calipers & lines
triple clamp
clip-ons; slightly bent
levers
front brake master cylinder
clutch lever perch
fairing stay, steel version
speedo/tach bracket
speedo cable
front seat
back seat
tail fairings, black plasti-dip
headlight, missing foam surround
rear black wheel & tire, black plasti-dip
sprocket & cush drive
swingarm, chain damage but useable
front and rear axles, spacers & nuts
rearset, stock. no shift linkage (93 style). Left side only. Bracket is bent slight inward.
rear brake caliper, line & master cylinder assembly
Please make reasonable offer. Shipping is from Troy MI 48085.
PM for pictures.
$75 for the rotors. I will have pics tonight after work.
Discussion Starter #15
I only have the passenger seat now. It is in good condition with no rips.
$45 with shipping? Includes the bracket for the trunk.
Discussion Starter #20
Still for sale:
front axle, spacers & nuts
front rotors
front brake master cylinder & brake calipers & lines
triple clamp
both levers
clutch lever perch
fairing stay, steel version, slightly tweeked
speedo cable
left rearset. no shift linkage (93 style). Bracket is bent.
1 - 20 of 37 Posts
