1 - 13 of 13 Posts
My RR8 is still stock, engine-wise, i.e. std exhaust and air filter etc, but I'm thinking of fitting a PC V, because:-
- At around 4000 rpm on a fixed throttle it 'hunts' slightly.
- I want to use Dynojet's QuickShifter.
Has anyone fitted a PC V to a stock bike and what improvement did it make - if any?
What map did you use?
Hoping to tap into other's experience before I launch into it myself.
I have never used the PC V but I have run the Bazzaz system on my 06 ZX-10R and it was great. I know for a fact that the Bazzaz system would fix your surging problem that you have. The best benefit you will get out of the PC V or the Bazzaz is a good smooth power delivery. On my ZX-10R I had aftermarket exhaust and I had removed the secondary throttle plates. The bike until I installed the Bazzaz with auto tune ran rough, vibrated a lot at all RPM and all together had what I would call in my untechnical jargon unbalanced fueling. All these problems were solved once I installed the Bazzaz and got the bike tuned. Which I did with the auto tune system so i didn't have to pay for a dyno time. The only problem that I had afterwards was that the bike was so smooth it felt like it had lost some of its killer power and edginess. When in reality it hadn't lost anything. The power delivery was just less abrupt. Oh and you may pick up a few HP but I wouldn't buy the system if that is all your looking for.
our bikes are tuned lean from the factory . as the temp goes up the ECU leans even more. yes even stock bike's benefit from fuel control. your butt dyno might not tell ya, but if you had a AFR gauge plummed in line, it would. btw ,
i use the PCV and the Auto tune on both my track/race bikes. either systems would work, the PCV is more tuner friendly imo.
I was looking at the Auto Tune module for the PC V, but am not entirely clear of its exact function. As far as I can understand, it uses a wide-band O2 sensor to automatically adjust the mixture, but does that mean there's no need to load a 'map'? Or does it use a special map that then allows it to auto-tune? And does it allow adjustment over and above what it automatically determines to be correct and if so, doesn't that mean you're back to needing a dyno to get the best from it?
well, you load a map ( from dyno jet, fuel moto etc) which is your base map. the auto tune , when enabled , suggest a "trim" to the map you are running on. on the PC111 if you had a dyno map and made any changes, say diff. pipe/ intake stacks, you would have to re-dyno the changes. the auto tune does all that for ya, so you can upgrade in stages .oh yea, diff. weather /tracks, you can make maps for each gear also.
I'm liking the idea already:)
Can anyone tell me though, does a UK RR8 have an O2 sensor in the stock exhaust?
I'm thinking it does and I've not looked hard on the bike for it, but if someone already knows, perhaps you could save me the bother. If it doesn't, I'll have to weld on DJ's mounting boss, but I'm hoping I won't need to do that.
On a slightly different note about the PC V, anyone got any comments about the best QuickShifter sensor to use? i.e. fitted to the rod and plugs into the PC V - not talking about any ignition cut module here.
DJ's own sensor is the obvious choice, but there is also the one from HM. They are basically interchangeable, but has anyone any experience of either/both that suggests one might be better than the other?
I also read somewhere that the PowerCommander's QS function doesn't work well at high RPM and an ignition cut system is better. Anyone any comments about this?
just a note, the DJ is mild steel, the Bazzaz is stainless steel.
OK, here's another question.
Since the PC V needs an additional module to work as a QuickShifter (on 8 injector bikes like the RR8), would it be better instead to use a PC V with the ignition cut module? Same number of boxes to add, but which is a better or worse idea?
Anyone used either setup?
The UK 08/09 blades have an O2 sensor on the stock exhaust. I fitted a PCV for a yoshi r77, with this mod you do away with the O2 sensor by plugging a resistor into the ECU circuit to make it "think it's still there", load up the PCV map for the pipe and away you go.
Look at the muffler from the sidestand side, the O2 sensor is facing the left hand fairing just infront of the rear wheel. The wiring runs back around the left hand side engine casing to a connector block just under the fuel tank.
Repper
Thanks for that. I'll have a good look today.
In fact I WANT there to be a sensor because the Auto Tune module uses a sensor, so good news:)
you shure the threads/ pitch are the same ? a wide band has a 18mm-1.5 pitch. i belive a o2 is diff. just saying.
1 - 13 of 13 Posts
