Hello
Does the pc111 from the 929 work with the 954 or do I need to get the 954 specific one?
cheers
sam
Don't listen to Zoltan...he apparently hasn't read the other PC3 threads...
The PC3 from a 929 will fit a 954 BUT the map formats are different. That means that you'll have to copy and paste a 954 map into a 929 map file. Not as hard as it seems. :)
Got this from an old post by Blue Toy:
what happens is that the zero map in a 929 map translates to a -5 (or some other value) when used on a 954, basically an offset.
which means that if you want a map value of 10 on your 954 you have to allow for the offest meaning that you'll have to set the map at 15 on a 929 PCIII
it's not really an issue and if you already have a 929 PC, it's probably worth your while just working around the offest, as it will be cheaper than selling a 2nd hand PCIII and buying a new one. It's not like it's something you'd do all the time anyway.
you just need to be aware that PCIII only go to values of 35 and -35 so the max and min values are also offest, so you might no tbe able to lean out the bike quite as much (only go down to an effective -30 but go up to +40) -I don't know anyone who has to go that extreme though.
he has probably posted in each one of them though :D
