Does anyone have a custom map or any map that is designed for a 2003 954 running a slip-on Jardine RT-One exhaust. Everything else on the bike is stock and I know other maps will work, just wondering if anyone has that exact map that I could use??
Thanks, Hellfire666
Is there a difference with the PCIII USB units for the 929, 954 and 1000? Looks like the same unit but the 1000 is $50 higher. I'm not sure if the 954 or 1000 is the best option for me yet but thought if the right deal came up for this unit before I got the bike, it would be good to know if I can use the same unit. Thanks.
I've got a map for you.....
1) Leave computer......
2) Walk to Garage
3) Get tools
4) Un-Bolt Slip on Jardine
5) Walk to Dumpster
6) Place Slip on Jardine RT One Can in Dumpster
7) Walk to house
8) Open Fridge
9) Pull out Beer
10) Go to Computer
11) Order Full System before you even go through the hassle of getting a map for a slip on pipe. Second Jardine money spent for a Can that Honda Racing will not even use, well except for the sticker.... Rest is Akro. How do I know, from the mouths of the tech guys at Road America
This should be a detailed "Map" to where you need to go. If not refer to diagram below
