bought a pcIII used, downloaded the matching map for my setup and no dice she starts once idles for a few seconds than cuts out. i believe its throwing a code 12. called dynojet and they didnt have much to say about it. the pc seems to be functioning properly as far as downloading and communicating with the computer just fine....any input
Disconnect it and see if its some weird coincidence that happened at the same time as installation or if its caused by the pcIII. If its still bad without the pc3 then your bike has a problem. If it works better without the pc3 then re download the map for it and make sure it is the right one. Seems silly, but ive seen it happen before, just clicking the wrong link.
If you try different maps and its still bugging out, take the unit to a PC dealer or tuning center and see if they cant see if your pc is busted.
