1 - 18 of 18 Posts
It's scary! HP curve is a straight line up to 161 HP. It did a best of 165.2HP but wasn't as smooth. The torque is 75.2 peak and is there from 8K and up. I only took a short ride so far, but acceleration is so smooth and the new trans is awesome. 3 hrs on the dyno breaking in and mapping were well worth the time.
Re: Picked the 954 up! dyna graph added
What a neat project - I'd like to read more about how it turns out once you get the chance to flog it.
My dyno curve looked like that but down a little more than 10 hp. Since power doesn't taper off to the limiter, you will find yourself hitting it much more often.
Nice bullet you have there.
IT's stock bore, Valve size and angle with new internals.
HRC crank, flywheel, generator
Erion Pistons & Cams
Ferrea Valves
Carrillo Ti Rods
Head work
thats bloody insane :thumb: good work mate. i want to see the faces of the guys on CBR1000RR's that you leave at the lights :evilaugh:
enjoy
Ferrea Valves
Carrillo Ti Rods
Head work
:nworthy2:
sound like it would be awesome, what's it like to ride, I mean does it lack any power down low for street useage?
Discussion Starter #16
The first ride was with new rubber so I took it very easy. I didn't go above 9K or even 1/2 throttle but it seems to pull everywhere. My 600 has a bunch of HRC parts and sputters badly @ 5K before the power comes on. The 954 just seems to pull no matter where you are in the revs. I'll be riding today and bump up the revs a bit, I'm taking it slow, breaking it in and I'm probably a little scared. The thing I'm most impressed with is the transmission. Shifting is posetive and effortless. It seems like an easy bike to ride around town and a great throttle control drill.
Discussion Starter #18
slowpoke said:
You did say you got the last 'pump gas' motor they had, right? :eyebrows:
As far as I know, Yes. This motor wasn't listed for sale, they forgot they built it. about a week after I said no to the FX motor they called and offered this one. I can get 98 at a gas station not to far from me, that's the "pump gas" I'll be running most likely.
1 - 18 of 18 Posts
