I have done some research and there are to many stories. So I thought I would ask others more familiar with these bikes.
I have a 1995 CBR 900rr and need some new clipons. What other years / makes and models fit the 1995?
Thanks in advance.
Sorry, can't help you much on that one but some research on specs should be able to tell you fork tube diameter in mm and go from there. It has to be the dimension up top where they mount of course.
Good Luck!
:hmm: I was under the impression that all the early blades ('92-'97) used the same ones...
... do you just need to replace or are you after sumthing different
