It seems like my HTEV is having issues... as in sticking half open (3-7k or whatever). I plan on pinning it fully open, and would like to remove the servo to save a couple pounds. Will there be an FI light? If so, any way to get rid of it?
If you remove the servo motor, there will be a permanent error but it has no effect on the bike at all.It seems like my HTEV is having issues... as in sticking half open (3-7k or whatever). I plan on pinning it fully open, and would like to remove the servo to save a couple pounds. Will there be an FI light? If so, any way to get rid of it?
You do realise the MIL is not the same as your oil light?Damn... I'd like to have the light off, in case I'm enough of an idiot to run it out of oil or something.
Should I pin the intake flapper open too?
Good to see people are still willing to make the effort for older models.Actually there is a way to get rid of the light. There is a guy on another forum making what he calls an ESRM. Basically a small chip that plugs into the original plug for the servo. Sends the ecm a signal and tricks it into thinking the servo is still working.
He originally came up with the module for the 08-10 RR, then adapted it to work with the 04-07 RR. I of course own a 929 and just installed a full system so i was in the market. I got ahold of him and spoke about it working on a 929. He thought it just might work so i went ahead and ordered.
I got the module and installed it a few days ago. Upon initial start up there was no light. I have yet to ride the bike since its been quite cold in Ohio. There has been plenty of guys confirm it works on the other forum. Might want to give it a try.
Same thing happened to mine - brilliant designTurns out there was just a little rock stuck under the cover for the lower pully... now that it's gone, everything works fine again. I don't see a reason to remove it when it's working fine, so I'll keep it as is.
any more info on this? who is the guy? does he have a website?Actually there is a way to get rid of the light. There is a guy on another forum making what he calls an ESRM. Basically a small chip that plugs into the original plug for the servo. Sends the ecm a signal and tricks it into thinking the servo is still working.
