Please help if u can. im on a deals gap vacation and i was oiling my chain and figured out my clutch never disengages. On the stand, i pulled the clutch in and as soon as i shifted to first then the wheel immediately started spinning fairly fast. I tried adjusting both adjusters and nothing. what could be the problem? Thanks alot for the quick responses. I will even pay someone $5 through paypal for the answer for the fix. THANKS AGAIN!
your still gonna have some risidual clutch pull even with the lever pulled in with the bike off the stand you wouldn't notice, but on a stand you will have spin....try putting it in first on the stand and running and engage the rear brake peddle, if the engine dies then you truely have a problem, if not...your gravy.
When the oil warms up the rear wheel should stop spinning.
Take the clutch plates out and clean them, they sometimes stick together when the bike has been standing for a bit.
Rocking the bike back and forth should be sufficient to loosen it up.
It also reduces that horrendous clunk into first gear on cold mornings.
Lol... that freaked me out too when I first experienced it. Never quite understood if it was the plates that still had some friction or if it was the oil transfering momentum between the plates
Hmmm...$5? Are you sure that's all you can afford? I can help you out - but my rates start at $10. So I guess you're gonna have to ante up my friend! Or else put up with a never disengaging clutch...which is it to be...??:eyebrows:
