Originally i thought the battery was dead so i got a new battery and put it in there and now i get nothing, the lights don’t come or anything. i put in new fuses including the main fuse and nothing happens. Even before I got the battery it did this. Any suggestion?
Maybe a relay. You might get a wiring diagram to trace voltage through the circuit. Look for corrosion and other non-conductors.
Most loss of power problems are due to bad grounding. Off of the negitive cable from the battery, follow ground and check for brakes in cable and where it's grounded. If everythings cool there follow positive wiring, check for brakes in wire and loose connections.
