1 - 13 of 13 Posts
i have had this problem before, but the dealer didn't do anything but temporarily fix the problem. it has a new regulator/rectifier, new stator, and a new battery. I'll ride it fine for a little while and it ill die on me either in a parking lot or out on the road, i need some assistance with finding out any particular electric problems with earlier blades.
Does it start again afterwards?
Is the battery flat when it dies?
How far/long can you ride before it dies?
basically what happens is that when i charge the battery i can ride for about an hour then it will die and won't start back up. and i have an led integrated tail light with resistors, and regular flush mounts in the front.
Clearly the battery isn't charging then.
It's either the stator or regulator or a break in the wires between them.
Have you checked voltage at the battery with the engine running to see if the system is charging?
I think either you have a week stator or a problem with a bulb. I bought some immitation HID bulbs off ebay and my bike 98 did the same thing. Switched back the bulbs, problem solved. The charging system in that bike isn't that strong.
the battery is only getting about 11.8v from the regulator but the stator is putting out the right amount of voltage. as for the bulbs i have normal dual filament bulbs in the front and led with resistors in the rear
11.8V is not a charged battery.
Do the volts rise or fall while the engine is idling?
ok let me explain this again, the battery is fully charged at 13.2v. i measure alternating voltage from the stator im gettin about 67v at 5000rpm, and hen i measure voltage at the regulator i am getting about 11.8v going out to the battery, so i am thinking that the regulator/rectifier needs replaced the guy i bought the bike from bought it from regulatorrectifier.com.
Certainly sounds like the regulator to me.
Physically disconnect the R/R plug and see if it has any corrosion. Clean the contacts to be sure. These have a habit of getting wet and rusting out.
1 - 13 of 13 Posts
