was installing power commander on bike this weekend and noticed the lower injector on the far right side of bike swiveled, is this normal?
you mean it moved a bit when you had your hands in there and it moved when you touched it-thats normal
moving on it's own like the girl off of the exercist head spinning-not normal
Your correct it just did move a little, it was the plug where the wires connected together that moved, no spining. I do not know if the injector was moving, just were the wires connected. I should of investgated more but I did not think of it till I had it back together. It was just a afterthought and now maybe I'm just nervous?
your fine bro, the injectors have rubber o-rings at the top and bottom, the fuel rail holds them in place, they will move if you push on them.....it's good, you have no worries.
