Hi Guy,s
Thought I,d ake here before I look elsewhere but has anyone fitted a quick action throttle to their road bike???
I know they,re available for Track bikes when you can remove the switch gear but I have not seen any that will still allow the use of the standard switches??
Has anyone thought about altering the throttle cable guide at the throttle bodies (I expect a fabricated cam would have to be made??)
easier to superglue a cable tie around the throtle barel on the clipon. Give your cables some slack to take the thicker barrel.
Better still, spend about a 100 bucks and get a proper quick action throtle and some used switchgear from the 1000rr on ebay. they go quite cheap... Thats how I did it on my 954.
Well today I decided to go the cable tie route...........yep it works,I even went for double thickness but the cable fouled up inside.
Thanks for the info
Nice to hear that it worked for you.
Some times simple things make a great difference and save you a lot of money...
