1 - 2 of 2 Posts
Could someone please tell me were the 4 way throttlebody sync vacuum pipe goes , The 5 way joint end pipe,Does this go in the vacuum port below the map sensor? If not which pipe goes there?
Also could somebody also let me know what pipe goes into the air housing directly above the crankcase breather hose that attaches to the valve cover . If i look inside the airbox on the left above were the crankcase breather hose is i can see a nipple for a pipe directly above it?
Thanks in advance guys.
Banned
Breather into the airbox. 4-way up to a 5th joint? That's the IAP or APS, means the same thing. Either the intake air pressure sensor fits there with the long snout off the sensor, or the air pressure sensor is the same unit, same snout sucking on a drum cover call it and this ear drum can be moved thru suck, sends up data up the wire from the change in vac pull. So if the snout is the vac port you mention... the bike runs, no codes, I think you figured it out already?
1 - 2 of 2 Posts
