I have a 1999 900rr. did the oil change with filter added oil it said to add. when bike is not running oil is almost to the top line in the window when bike is up right. when running i dont see the oil in the window. is this normal?
You don't see the oil because most of it is being circulated around the engine. The window is only for viewing the oil when the engine is turned of and in an upright position.
thank you! just wanted to make sure nothing was wrong.
