1 - 10 of 10 Posts
DCEMotorsports : I got an HRC seat pad from LINK.  Sorta pricy but good quality.
Same, but I got mine from Dan Kyle.  Worth the money.
Lockhart Phillips also sells foam squares (in 1/2' and 1/4') that you cut to the shape you want. I don't use any foam though, just sit right on the fiberglass.
I ended up ordering it from Street and Competition for $8.99 a square ft. They sell self-adhesive in 3/8 or 3/4 thickness. I bought the 3/8.
Trackfan : Be careful if you glue the HRC pad. That thing has some memory. Don't ask me how I know.
We tried everything with mixed success. The only thing that completely worked was about 2 full tubes of SuperGlue and 3 tie downs wrapped around the seat/tailsection overnight.
Caution: Make certain the seat is aligned the way you want it before actually putting it on the tailsection, as the SuperGlue isn't pretty if you have to move the seat once the 2 pieces are in contact with each other.
1 - 10 of 10 Posts
