Hi peeps, anyone got a clue what gear pedal to use on my 99 fireblade, to reverse the gearshift? I believe a vfr shifter is the way to go, but unsure of what year/model to use. Thanks in advance John 馃槑
Hey buddy :wink
I use a set of Attack rear sets on my 99 track bike, with a smaller diameter shift rod to clear the frame. You can certainly try the offset VFR one, or maybe even the regular one from the 92-94 (there was no linkage on those years in the US). That might work if you're using OEM rear sets. I just took the knuckle on the shift shaft and turned it upside down.
Nice one mate, thanks for your help. Will try that. Cheers 馃榾
And sorry, forgot to add that I think the VFR one is the same years 94-97 or so for the offset shift lever.
I know guys have used it on the 929 and 954 for GP shift with OEM footpegs.
Good luck.
