i had similar ticking cracking noise on a nissan 200 car
after much searching it was a tiny crack in the manifold.
it made a fair bit of noise and i thought it was a cam problem for ages.
as the engine got hot the noise disappeared as the crack tightened up with the heat.
it was welded and that was that.
not that i wont to worry you but there were some issues with the rear cams on a few of the early sp1's when raced or ridden very hard and was a overheating issue but this was quite rare.
this caused premature wear on the rear cams so think this wont apply to you.
all i can suggest bud.
