Does this bolt up pretty easy? And much of an improvement? I don't use back brake at all on the street, and probably should use it more on the track....
The rotor is a new aftermarket one laser cut for less weight. Yes it is a bolt on mod and the biggest benifit is rotating and unsprung weight savings.
I know where that rotors are from. Would you please be kind enough to put it on weight? It would be really nice to see how much lighter it is compared to stock which is at about 800 grams
