1 - 20 of 20 Posts
01-02 were the only changes besides color if I remember right.
went from 54mm to 62mm throttle bodies
swingarm got 16mm longer I think
wheels went from 6 to 5 spoke and are lighter
I hear the trunk is bigger
from one rad fan to two....which everyone removes since it makes it run hotter
ECU
I think that is the major stuff
...windscreen got taller
a few more HP also. The '02/'03 steers quicker. The swingarm is probably the most significant change affecting that. The forks have top out springs on the newer gen.
the 00/01 are stronger motors stock to about 8500 rpm. The 2002/2003 are slightly weaker but peak out better and offer more potential to build.
If given the choice and the money benefit is worth it, definitly get a 2002 or a 2003... The swingarm and chasis changes alone make it a way better bike.
And yeah, I had a bastard 2001 bike, no swingarm spools, what a drag!
More questions..
Can I put a 02 or 03 swing arm on the 00 or 01?
Same goes for the throttle bodies?
I am seriously considering the RC51 that flitzer is wanting to trade me for my 954. I have always wanted an RC.
ViciousRR : More questions..
The swingarm yes, Thorsten sells a kit to do it. I'm not sure why anyone would change the TB's on the 00-01, they work awesome, and unless your bike is in WSB, I don't think you need the extra HP. Once you get the RC, you will not miss the 954 at all, it's a little down on ponies, but who buys it for that anyway? I bought it out of sheer desire to have one since it came out, and haven't regretted it since, even while passing 954's and 929's on the straights on the track
Discussion Starter #15
I wasn't going to change the TB's, it was more if I really could.  I assume the wheels can be swapped without hassles also.
I had a 98 superhawk before my 954, and I miss the obnoxious grunt and sound it had.  It was great for canyon carving.
Here is a pic of my old superhawk.  It had a custom ducati silver paint job, aftermarket clutch a break mastercylinders.  Braided lines, and lots of stuff.  It was great!
ViciousRR : I wasn't going to change the TB's, it was more if I really could.  I assume the wheels can be swapped without hassles also.
Yes, the wheels are an easy swap with the nod going to the 2002-2003 wheels being a bit lighter...
heres a noob question, i really want the sato banzai mount exhaust but i have a 2001 :( are the exhausts interchangeable between all years of rc51? im betting on "no"
1 - 20 of 20 Posts
