1 - 12 of 12 Posts
red light giving me 4 strong red and 5 flashing one -
then 8 flahes .
anyway to translate that info please?
thanks
slow flashes are the first number, fast flashes indicate trailing numbers.... 5 slow then 4 fast would be an error code 54. 5 slow, 4 fast, break, 4 fast would be 544 not sure if bikes have 3+ digits though, I know cars do. Once you get the code look it up in your owner's manual and it will give you a brief description of what the ECU thinks is wrong
Yes, but there is no code 45.
Code 8 is the throttle position sensor.
Since you don't have a manual to check the codes I'm guessing you aren't going to be able to check any of the sensors anyway though?
Is the bike actually having any problems?
There is a pause between flashes so it can indicate multiple problems.
The most I've seen at one time is four codes :)
is there any software or code manager to red the bike from an entry point likecars OBD1 or OBD2?
Did anything happen to the bike just before it started throwing codes?
Not as far as I'm aware.
Theoretically, dealers should have a device for testing ECU's but I've never seen one.
I don't know of one but they're listed somewhere on the forums.
1 & 2 are MAP sensor
7 is Coolant temp
8 is Throttle position
9 is Intake air temp
11 is Speed sensor
12-15 are the injectors
18 is Cam pulse generator
19 is Ignition pulse generator
33 is the ECU
34 & 35 are the exhaust valve
21 & 23 are only in Catalytic converter ECU's.
1 - 12 of 12 Posts
