Hello everyone
One day my rear blinkers stopped working (the ones in the front work ok, and the brake light works good too)
Is it possible that the relay is broken? I guess there is a relay for the front and one for the back... Am i right? What should I look into?
Thanks
Hello everyone
Thanks
Should only be one relay. I bet the connector came loose. Did you check the connectors from the main wire harness to the rear signals? You might need to take the rear side panels off to see them.
It's also possible that both bulbs blew out. Do the fronts blink really fast when you turn them on?
I didn't, I will have to do that. They both stopped working at the same time, so I guess there is a connector loose.... Btw do you know if I need to remove the lower panel to remove the side panel? It seems like a pain in the ass... haha
Cheers
Cheers
Cool, update when you can :thumb:
I was dumb, so dumb. After removing every panel i realised both bulbs were gone, I installed new ones and they are working now 😅
I thought it was the relay or something because they both stopped working at the same time:LOL:
