Rear Hugger for 09 RR with ABS
1448 Views 3 Replies 2 Participants Last post by  GUZZLA
I've been wanting to fit a rear hugger to my blade with ABS fitted but the manufacturers recon they don't fit the ABS model.
The only difference I can see is the ABS sensor wire running down the inside of the rear brake line - which is easily relocated.
I would be most appreciative if someone could clearly show or tell me why it wont fit.
Thanks in advance.
I managed to find my answer after spelling 'tyre' the yank way (tire).
Here's what I found for future reference thanks to frenk in another post...
I fitted an original Honda hugger from the accesoires cataloge. The blue one which is very nice for the HRC colors. It only touched the ABS box once when riding with a passenger and forgot to stiffen the rear suspension. It was still with the original factory setting position 4 of 10. So it was too soft when I hit a bump, it only left 2 little scratches luckily. No more problems since, because now the rear is on post 6 of 10 and that hard enough.
Looks like it's time to go 'tyre' Hugger shopping now:rotfl::rotfl:
Tyre is the "proper" way of spelling it :rotfl:
Just make sure you stiff up your suspension if your going to carry passengers as Frenk said :thumb:
Cheers Twincan,
It already has a stiffer rear spring and I removed the pillion pegs so I should be sweet. I ordered the Hot Bodies hugger from Bike Bear Warehouse owned by Matt Maladin here in OZ. I went with gloss black to match the rest of the bike as every man and his dog have carbon fiber and I'm sick of it now.
I'll report back on how it goes.
PS: Has anyone seen the price for the Honda huggers??? :hss:
