What are you guys using to shim up the rear shock? I'm thinking of shimming the rear shock mount 4 to 6mm, but can't find any aluminum production shims. Are you guys just using steel washer? Thanks for the help.
Rick
I have an adjustable Ohlins but don't see any reason why you shouldn't use a steel washer. Might even be better as it will be less likely than aluminum to "squish" when landing your '54 after a triple jump!
Just make sure it is painted or protected in some way so it doesn't rust.
