1 - 12 of 12 Posts
I am trying to remove my rear wheel and I'm having some trouble. I have removed the axle nut, spacer, loosened the adjusting bolts on both sides and removed the caliper. Is there anything else I'm missing here? I have been pounding on the rear axle for a while with a rubber mallet and the axle will not budge. I dont want to continue ripping on it if there is somehting else that i need to adjust first. Let me know if you have any ideas here, I'd greatly appreciate it.
Stick your foot under the rear tire to give it a bit of leverage, then try tapping it with the mallet again. When reinstalling the rear axle be sure to put some grease on that puppy.
I've had tension off of the rear axle the whole time. It has been propped up a lil bit, but still no movement. I've tried everything I can think of and the local shop didnt offer much help. Not sure where to go from here...
Was the bike ever crashed or did you damage the rear wheel?
I wish I could offer more ideas but it sounds like either your axle might be bent or it just might be seized in the wheel. Try squirting some WD-40 and see if that helps.
I've never owned a 954 so I'm just taking some guesses based on some other bikes I owned in the past. I'll try to think of some other stuff.
WD-40 didnt work either. The bike has not been crashed by me and the prevoius owner said it hadnt been crashed either. So I'm thinkin it is the axle, its most likely seized.
Had the same trouble with my 954, seized inside the wheel. Try plenty of WD, CRC etc, leave to soak in for a day or so then get a block of hardwood that you can hold on the end of the axle,(no nut) and get a mate to hold another block of wood against the swingarm beside the axle on the other side to make the axle gets all the force not the swingarm and the swingarm bushes.Took a few good whacks with a reasonable sized lump hammer but it did work. Carefull not to miss, those swingarms dent easy, good luck, Macca
Yep...that would hurt ya!
Something is wrong - something must be bent or out of aligmnemt. That axle should come right out. Take a piece of PVC that roughly fits the dimensions of the axle and use that as a tool instead of directly hitting the axle. This will allow you to hit much harder with no damage to the axle.
That is the issue for sure the axle is seized on the bearings and the spacer in between the bearings.
Worst case scenrio you may need to replace the axle if you damage it. They should not be that expensive and you may find a used one cheap.
Seized axles usually happen like that when people "pressure wash" the bike forcing the lube out and water and dirt in causing the seizure.
Pressure washer = bad around bikes.......
What lube should go on to the axle? When we had mine out, we just re-inserted the thing after the chain and sprocket replacement. Not knowing the solution, I allowed it. Fortunately no pressure washer here.
1 - 12 of 12 Posts
