1 - 9 of 9 Posts
took the exhaust header off, I'm sure I will need to put new gaskets in once I get another header, but not sure how I should go about removing the old ones?
TIA
They are not hard to get out. I use my finger or a small flat screwdriver carefully to lift the inside edge and remove the gasket. They just pop right out.
Here's a tip for installation with the new headers. Wipe a thin coat of (clean) grease on the new crush washer and seat it to place with your hands. The gaskets won't fall out when you intall your header!
HTH
maxib : They are not hard to get out.  I use my finger or a small flat screwdriver carefully to lift the inside edge and remove the gasket.  They just pop right out.
HTH
I remebered when I installed the new header I used a thin coat of seal-a-gasket which held the gasket in place while I installed the header.
It seems the seal-a-gasket baked the crush gaskets in place, so I had to use a little more force then I did before.
Thanks fellaz
i see its too late now but i was just gonna say that i have taken my factory header off and installed a serpent header - 1 year later took the serpent header off and put the factory header back on - 6 months later took the factory header back off and put another serpent header back on it and have not touched the crush gaskets and not even a threat of exhaust leak
rather than putting grease on the gaskets I just bolted up the headers with a couple of turns on the bolts, then I dropped the gaskets in from the top edge which was open, but the bottom edge was closed due to the way the headers hung, no possible residue issues that way
Ben
FullForce : i see its too late now but i was just gonna say that i have taken my factory header off and installed a serpent header - 1 year later took the serpent header off and put the factory header back on - 6 months later took the factory header back off and put another serpent header back on it and have not touched the crush gaskets and not even a threat of exhaust leak
Yeah, I reused the gaskets when I installed my Arata. I was going to put new ones on, as recommended, but I didn't think of it until the day I was working on it. Of course, my local Honda dealer didn't have any in stock. I put some sealant on them (as well as the rest of the exhaust) and I have no leaks.
1 - 9 of 9 Posts
