1 - 10 of 10 Posts
I have a bad fork seal on my RC51 and was wondering if i should replace it myself or should i have it done by someone....and what does it involve doing a fork seal
Wowzer! I replaced springs, seals, and fluid on my F3 forks but damn that picture you got Red Rider kinda scares me going into my 954 forks. Prolly this winter I will be wanting stiffer springs and change fluid. I might try myself but maybe send them in to get done.
Banned
sometimes you can find a "deal" on fork seal driver tools on eBay. Otherwise MotionPro makes good ones for around $60.
Here in Phoenix it costs $90 to take the forks by themselves in to the dealer/shop to have them install new seals and fork oil. On the bike they charge $200.
I made my own fork seal tool out of a 1-1/2" pvc coupler that I cut in half and held onto the forks with two worm clamps.
Beat the back side of the pvc with a big screwdriver and a hammer and your seals will set without damage.
service manual goes step by step on how to replace them and then i just took it to a dealership to tap the seals in, didn't even charge me since it took less then 2 minutes to do
I'm with Red on Cartridge shocks. Take'm to a suspensions shop, not stealer. They are complicated and more importantly, you must disassemble them entirely in order to clean them properly. the damping orafices are tiny and can easily get clogged by particulate. The other reason for the suspension guru is that they can check your parts for problems as they do it.
If you had Damping rod forks, it would not be near as complicated and the holes are alot bigger.
Why hello there Jesse. Lol wanna come do my for seals?
Been out riding much this year?
got a pic of this home made tool? I'm too cheap and the dealer round here thinks they're sellin gold they wanted 50 bux to swap a set of tires (wheels off the bike not even balancing):rant: K I'm done
1 - 10 of 10 Posts
