1 - 11 of 11 Posts
My cbr900's rectifier fried and took about 6 inches of 3 of the wires and the connector so I was wondering if I should just replace like 8 inches of the wire or all of it through the harness. Maybe even put a bigger gauge wire on it. Let me know Thanks.
I'd replace the wire (it looks better) but would not use thicker wire. All you do is move the issue to the next weakest point and worse things could happen.
The wires to the stator or to the harness?
Make sure you check the stator as well before replacing the rectifier or you might just burn out the new one as well.
I took it to canyon honda a couple weeks back and had them diagnos it and the tech said he thinks the stator got hot and melted the connector and made a couple of the wires touch and thats what he thinks happened. So just replace the part thats burnt with the same gauge wire. And I just installed a new stator before this happened
No its aftermarket got it from electro sport I installed that around may and the rectifier went bad around november
I have the new one on and I havnt started it yet. If anything is still wrong will the rectifier fry right away or would it get really hot again then goes bad.
Would putting a new stator cause the rectifier to go bad..the stuff is old the bike has 30k on it. And I dont want to fry the new rectifier on it so I havent started it yet
If the stator is bad then it will fry the rectifier.
Whether it'll do so in two minutes or two weeks I don't know.
There must be plenty of people on here that have replaced one without checking the other.
I would guess within a few weeks but it may damage it immediately for all I know.
Just check the stator before you hook it up.
A failure on one can cause the other to fail; I have never heard of it happening right off the bat. The other fails because it is being asked to do more to compensate for the other.
1 - 11 of 11 Posts
