So, My buddy wants to learn to ride motorcycles... His uncle gave him a '95 CBR900RR for $500. The price is right, right?
I tried to convince him to start out on someting a little smaller but he wants to ride this thing. Oh, and it has an auto-shift-gizmo installed so it has probably been dragged (abused).
So, we limp it up the ramps into the back of my truck with both tires flat and haul this bitch back to my garage. I am going to get it running!
Here is what I have found.
The bike had been sitting for 5 years before about 2 weeks ago when my friend and his uncle changed the spark plugs and supposedly drained the tank and put in fresh fuel.
I tried to start it and it fires but not strong enough to idle. I pulled the tank and drained the 1/2 gallon and it looked like mountain dew and smelled a little varnishy. I changed the fuel filter which was black and checked the fuel pump operation. the points where smoked so I changed them. I then re-assembled everythng and FILLED the tank and added a bottle of fuel system treatment which was recommended my my local honda shop. Hit the starter and bang, it idles... Weakly but it idles. Small victory. As soon as I even touch the throttle, it dies. I check the pipes and find that the 2 cylinders on the left are firing but the ones on the right are not. I checked the coils and found that each one fires a cylinder on each side so I am assuming that spark is not the issue. I am guessing that the carb on the right is all gummed up with varnish and maybe the float needle is stuck shut. Who knows what I'll find as I tear into the beast.
I am going to pull the carbs and rebuild them. Any advise or tricks? I am a heavy equipment mechanic, hydraulics specialist. the smallest parts I work with weigh over 20 lbs. Ive never had one of these new-fangled carbs apart.
Thanks... Badandy:evilaugh:
