I have a RR-R (94-5 Foxeye) and weigh in at just under 13st.
But now I use Racetecs and they are great...(on a 17" front rim") :evilaugh: :evilaugh:
So.....
I would suggest trying a 17" front rim... :thumb:
Before you buy check out this forum to find the correct 17" front rim, as the very early and later blades did not run the same front rims as the 94/5 foxeye....:idunno:
See if someone more local can "lend" you a rim for a trial run (or a bike that has been converted)
Good Luck :hmm:
Is how my blade felt with a 16" front wheel - but good news is it feels stable and planted with a 17" front rim....
17" front rim gives you options... I have always run Pirelli Corsa's in the various versions.... well the TT guys can't be wrong....:huh:
So.....
Good Luck :hmm:
