hi everyone. ive just been offered a mint complete front end and a mint swingarm and wheel off a 98 rrw. they are very very cheap! but will they bolt straight onto my rrv? many thanks
When you say complete front end, do you mean wheel, rotors, calipers, axle, spacers?
If so, then yes, it is a DIRECT bolt up to your 97 RRV. The 98-99 forks were 10mm wider than previous years, had 20mm larger diameter rotors and the hub was 10mm wider as well.
The swingarm itself is also a direct bolt up (had a 99 fitted to my 95), but you will need the 98-99 brake mount bracket.
HTH.
Cheers,
Sime
yeah ive got the complete front and rear end, wheels, rotors, brakes the lot.the wheels even have brand new tyres on! thanks for the reply mate
