Afternoon,I have an ongoing running issue with a 2001 cbr600f just dies after around 10-15 minutes of riding I've already replaced alternator rec/rectify which both were knackered so battery is charging fine and new battery.plugs changed and a service oil ect.no rough idle just dies on the spot I have mentioned to honda could it be the hiss system and they said it's rare has anyone had this issue before?many thanks.
I take it that it is an FI model? If so, are there any thought had stored in the ECU. A workshop manual will show you how to read them and it might help diagnose the issue.
It might be something like a faulty cam sensor Failing when it gets hot, for example.
Discussion Starter · #3 ·
It is a F1 model someone said on another forum it might be the tank breather problem something I need to look at to rule out are the cam sensors a known problem.
possible - when it conks out try opening the fuel cap and it there is a sudden inrush of air that could be the problem. I had, on a fireblade carb'd model, pinched one of the pipes when re-fitting the tank and it wouldn't run over about 6,000 rpm so stranger things have happened!.
