1 - 16 of 16 Posts
I started the creation of a chock mount that mounts on e track running length wise. I could not find a solution that made me happy so I created another one that I am not happy with :D That said I plan on the next being improved and the design and knowledge might help others, so here it is. The design consists of a Pit Bull chock mounted on red oak with a iron bar attached to the oak and etrack clips. The problem with the design is that the fit is to tight, when attaching the platform holds the clips to high. To mount to etrack you need to attach the bar then bolt on the red oak platform. One design I am considering for the next is to fasten the clips to the bar with a 1/2 bolt interface so that the clips can rotate.
The e-track clips are from rope ties with the cloth and d-rings cut off. These are welded to a 2x3/16" iron bar cut 16" long. This is the first area that can be improved. The clips should be able to pivot and I would suggest 1.5" bar since the e track clip slot is 2" and needed some grinding for fit.
Discussion Starter #4 (Edited)
As stated in the intro the bottom of the table was routed out. The height needed to use the slot in the clips was 0.75" which is the height of the side rails, so if the tabletop was routed to allow the bar to lay flush, perfect fit.
To ensure the table could hold the weight I had the RR front wheel on it for about 1 1/2 hour with no signs of bowing. The back was in a Pit Bull stand.
Now some lessons learned and comments:
1) Always pre drill hard wood before installing wood screws.
2) The ends need to rotate to clip in
3) The basic design seems sound
4) I need to road test the design before building table #2
5) I suck at wood work
Keep tryin' sheepster! :thumb: And never forget your signature. :D
Seriously, good luck with it, I know you'll get 'er done.
Red Rider said:
Looks like a lot of work. :thumb:
Lots of measuring and thinking. The second will go faster when I solve my clip issue. I am debating on the mount on bolt idea or leaving more bar free so it can flex some.
Also any opinions on if the tire sitting on a bolt head would be bad for the tire? I am thinking of making a cap of some sort...
glue a piece of carpet over it to provide some padding and traction for the tire
Just counterbore it a bit if it concerns you... :idunno:
Both good suggestions.
The carpet would work but it is red oak ;) trying to maintain a spiffy hard wood look.... Tires are more important though. Oops just thought of it, this one the bolt has to be able to be removed until I improve the design.
Baketech I had discussed that very thing with my brother, the thing is the lumber is 3/4 thick (true size) and had 3/16 routed out for the bar already. I was afraid countersinking would make it to thin at the mount point.
It's not under any tensile load because the bike is on it...you could go to (2) smaller fasteners to get shallower C-Bores, if you were concerned about it... :thumb:
Discussion Starter #15
Interesting Baketech I believe you are right. The side rails are the support and the bolts are more front to back (attaching the rail). There might be some hole boring tonight...
No carriage bolts since my design failed. If I make the ends to rotate so I do not have to unbolt it to get the bar on carriage bolts will be used (hopefully the next one)
as far as the traction surface, do a rough sand to it? better than smooth wood if you aren't gonna cover it.
1 - 16 of 16 Posts
