Was doing research for my buddy to set his rev light and came across this. I thought I would put it on here just in case someone else out there in the Org needed the info. :thumb:
Hope this helps some of you. It's pretty useful info.
WATCH AND LEARN!!!
To set the "REV" light function press and hold "SEL", then turn the bike on.
Release the "SEL" button and press the "RESET" button repeatedly until the needle is at the desired rpm for the shift light to activate. (anywhere from 4k-12k)
After desired RPM is chosen, press "SEL" once
Repeatedly press "RESET" and choose from the following:
Fast flash - high brightness
Fast flash - medium brightness
Fast flash - low brightness
Slow flash - high brightness
Slow flash - medium brightness
Slow flash - low brightness
Solid light - high brightness
Solid light - medium brightness
Solid light - low brightness
After desired REV function is selected, press "SEL" to finish
Cheers, Sorry Admins if it's a repost.
Re: Setting your Rev Limiter light on the 04-06 1KRR
good info, but named incorrectly.. not the rev limiter it's a shift light.. but good post..
LOL had the limiter on my mind from another post I read. Sorry about the confusion I fixed the title. Thanx Davis for pointing that out.
