1 - 20 of 53 Posts
I was cruising along pretty good with my shed today, had the floor frame all in place and only a few more cement blocks to put in place and my leg fell in a hole up to my knee. I was like what the hell, I had walked over that spot so many times before and I guess it just had enough today. so I dug it out and ended up with a hole almost 2 feet in diameter and 1.5-2 feet down that seemed as if I found all of the hole. so I grabbed this big rock I had moved out of the way to start with and threw that in there. musta weighed almost 50 pounds but it took up a lot of the room. then I filled it back in with the dirt I had dug out and still had to get some more to completely fill it in. this shed has turned into a pain in the ass to build but I have nothing else to do so it keeps me busy for awhile. Assuming I have no set back tomorrow (me and my father are gonna use some special tool that sticks into the ground to find any more holes that might be there) I'll have it all up and ready to go. My bike will appreciate having a home finally, not just for the winter but year round.
TGZ13 said:
There is always something bro. We just about finished up the last of our remodeling in the garage and basement and it was just one of those things where if something was going smooth you could be sure it was only a matter of time before something happened
always. first problem I had with this project is the directions to putting the damn thing together (its one of those metal sheds). basically now I'm just going with if the hole is too small for a bolt then a screw goes in there.
i am asking santa for a shed for my outside too. I am going to put the yard crap in it as well as paints and stuff.
Santa is looking at vinyl sheds, did you happen to take a look at those? why did you choose what you chose?
Discussion Starter #5 (Edited)
nope. only ones I looked at were wood, for about 2 seconds because they are way too much money and metal. the plastic ones are all too small for a bike, atleast the ones I saw. My only stipulations were I coulf dit my bike in there on stands and it was as cheap as possible. The shed was $199, the floor frame kit was $60 or so, I've used about 24 cement blocks I think so that was like $26, one piece of plywood for $21 (my father had the other 2 needed). And the anchoring kit was $60, that was only piece I didn't get at Lowe's had to order that form the shed company. so I've spent under $400 and my bike will have a home for itself.
I was putting it up all day today. I was out there from 9:30-6 (an hour and half after it got dark) and my father came out a few minutes after me then one friend around 12:30 and the other around 12:30. and we didn't finish. it says to get it all done in one day when you actually start putting it up but we just couldn't go any further. I have 7 of the 10 roof panels to put on, and the rollers onto the door and put the doors on, then build a ramp. Its suppose to rain and be windy tomorrow but I think it'll be ok. the 3 roof panels I have on are small ones so they won't be much of a "sail" in the wind. so I think it'll be alright tomorrow. should be decent when its all done though.
Bubba if the vinyl shed assembles like a metal shed may I suggest you put down a slab of concrete for your floor. it'll be much much easier. I had to get all the blocks level and shit and then get the frame square (which you'll still have to do). mine must be a tiny bit unlevel and maybe got off square as we were putting it up (the frame was spot on before we started putting the walls up) and it made some of the holes not line up. so I had to kinda shimmy it and force it into in some spots for the holes to line up.
not that I wanna put my bike away for the winter but it'll be nice when its all done.
thanks for the hints :thumb: i am sure all this info will save me some frustration.
yup, I almost wish I had done the concrete slab. I thought I had all my cement blocks level but of course they must have sunk a little especially after putting the plywood down for the floor. had to "force" a few screws in and had to drill a hole in one brace cause it was just way off (they probably put the hole in the wrong place on that one cause all the others that were off were only a touch off). but the rain held off for awhile this morning so I got the roof on there. just need some edge roof pieces that attach all the roof panels together and then hang the doors and put some trim pieces on. then wait for the anchoring kit to come (ordered it friday I think so they'll get the order on monday as they aren't open weekends in the winter and hopefully they'll get it sent out within the week).
bubba said:
Because a poured slab makes it a permanent structure. If it's a floor up on cinderblocks, it's considered a temporary structure. Depending on your town/state, permanent structures are taxed, temporary ones aren't.
Thanks HGT. Well put and correct as far as I know.
Now if you pour a slab and never pull a permit....................................
but we are not allowed to talk about stuff like that on Fireblades.org. :rolleyes:
:banned:
:smilebig:
Discussion Starter #14
sheepofblue said:
Another advantage of a cement slab is you can attach a mount for securing the bike to (maybe even when poured)
for the shed I got they really suggest also getting one of their anchoring kits, I ordered the one that comes with augers that you just stick inthe ground and it hold the hold structure down. they also have one for the concrete slabs and it comes with a masonary drill bit and the anchors that go into the concrete.
I could put a secure mounting thing in too. there's a central piece of plywood thats 22 inches wide and I could pull that up and bolt in a front wheel chock then put the board down. That would be pretty secure and I could just ride right into the chock. thats a good idea but I'm not gonna do it, it would take up valueable space.
Discussion Starter #15
I guess its good I didn't have one poured cause I didn't know that. besides I live in a duplex and I'd have to ask my neighbor if the truck could drive on their lawn to get to the back of the back yard cause my pool doesn't allow anything even as big as car back there.
Discussion Starter #16 (Edited)
Re: Shed building (2.0 now with Pics)
its actually been done for a few days now. came out pretty damn good if I do say so myself. first pic is where I used to park my bike, second show how far back the shed is in the yard, third shows the shed closed and fourth with it open (notice the swingarm sliders, thats was todays project. and the boxes are all car engine and tranny parts, and on the left the cover I no longer need)
Nice work!! :thumb:
Are you going to put in an anchor for a nice big chain?
Discussion Starter #18
soon2b954 said:
Nice work!! :thumb:
I assume you mean to keep them from stealing the bike then no. where the bike used to sit I would just throw the cover on and on more than on occasion I forgot the key in the ignition. I'd go to grab the key to take bike out for a spin and couldn't find it.
If you mean "anchoring" it to the ground I'm just waiting for the anchoring kit to be shipped here. a shitload of aircraft cable and 18 inch augers. there was some pretty good wind and rain yesterday and it stood there without a problem but just in case we get any of those little weak hurricanes we get up here on occasion I'll be safe.
1 - 20 of 53 Posts
