1 - 1 of 1 Posts
Sorry need some tech help.
Installing the shindy steering damper on a 99 900rr. I had to re-route the clutch cable to go under the speedo bracket to make clearance, not sure if this is going to cause any problem.
After I clear the damper from all cables, tighten up all the bolts, but the damper itself still appear loose. There is a huge play between the damper and mounting bracket... Can someone tell me if this is normal or I screw up somewhere? and how I can correct it? Thanks!!
1 - 1 of 1 Posts
