I bought a SC33 project bike almost 2 months ago and been reading a lot of fireblades.org, and now I have a question. I'll save my stupid story for a build post.
I'm in the process of streetfighter'ing the SC33, and want to convert it to a single seat (have a spare subframe with plastic, stored safely for the future). Most streetfighter 'blades I've seen use a different seat frame from another bike, or use something fully custom or heavily modified. See the black example below.
My question: Is it safe to just chop the rear subframe behind the first pillion mount and ride like that (see photo below)? Considering it won't be carrying a passenger, is there enough strength left? Should I worry about torsional rigidity?
I've found only one example of this (see silver example below) and wondering why I haven't seen more. Are they unsafe, or do people just think they look like garbage?
It looks chopped rather than purpose built, I’d be inclined to fab a sub frame from scratch if you have the know how. Not sure what something like that would cost to have done :unsure:
Or chop it where you have shown but lose the bracing plate to close the angle between the upper and lower rail then re brace if that makes sense?
Thanks @S4m . Custom frame is definitely the way to go if I had the know how. Even cutting and rebracing as you say would take some welding, and I wouldn't trust my welding ability on a life-or-death component like this. I'll look into a fabricator, but in the meantime it sounds like there's no structural reason not to cut where I have indicated. I found a post on a streetfighter specific forum that answered the question. Consensus there was also "do a custom frame", but also that these cuts were safe.
Whats up man. You should check out customfighters.com for stuff like this.
I’ve done a bobbed 929 like the one you pictured. I cut it where you indicated and had a plate welded to the back for structural integrity, plus a place to mount my tail light/plate. Plenty of good info out there for ya. ;)
