1 - 17 of 17 Posts
Hello fellow riders!
I have an '08 'Blade with a Yosh R-77 carbon slip on. I bought the bike with the Yosh already on it. The bike is obviously rippin fast when you get above 5k rpm, but feels a little "groggy" any lower.
Do we think (or know) if a stock exhaust would make a noticeable difference in the lower RPM's? My only thought is that maybe the "high flow" slip-on exhausts relieve too much back pressure in the lower RPM's?... ONLY A THEORY. Don't castrate me for saying that- these threads get a little violent at times :nono: :rolleyes:
I THINK this was an older thread, but I'm hoping to rekindle this subject back to life. You '10+ Fireblade riders, lets hear from you too!!!
Thanks
~Matt
Honda titanium exhaust valve.
Its regulated bybservo and throttle cables,it open the exhaust in different percentage depending what rpm range ur on,
Ex.. low end eexhaust opens 1/4. Full throttle all way, honda installed it to create better power. Flow,and more torque
The 1000RR doesn't have it. So he won't lose anything.
Discussion Starter · #6 ·
So do you guys think the bottom end power that's lost had anything to do with freed up back pressure?
Could have a slight effect but the changes are so minimal when changing a muffler that you should be be able to sort it out with changes to fueling (re-mapping).
Discussion Starter · #8 ·
aka a power commander or bazzaz, something along those lines?
yes when u free up exhaust, less back pressure less torque. but like he said PCV or tuner will fix it. everyone says to run a tuner after a can upgrade or air filter.
Discussion Starter · #10 ·
That's what I've heard as well. thanks guys for confirming.
My opinion here- don't worry much about it. I would certainly recommend tossing a PowerCommander on it, but that is due to the smoothness you can get from the throttle with it. I do not personally dip below 5k rpm very often as I like to be close to the start of the "real" powerband on my 954 (about 6500rpm). I tend to cruise right at 5k and have adjusted all my shifts to put me at a minimum of 4500rpm (MINIMUM) when I shift up.
Discussion Starter · #12 ·
When you say "have adjusted all my shifts" you simply mean when you shift the bike, correct? Thanks, btw. lol :thumb:
Yes, this is purely my preference on when I shift as to keep the revs and power there for use if needed. A fuel controller can help to increase efficiency in order to avoid some loss of power/tq, but it isn't going to works miracles.
Don't understand how PC can affect the exhaust back pressure or flow for that matter as it controls the fuel mapping into the chamber.
RR8 (an onwards I presume) have two valve in the silencer section as well as O2 sensor.
One valve opens at around 4k, the other above 6~7K. So the exhaust flow (and noise) is dynamically tuned depending on the engine rev.
I am not surprised your bike is running differently with this removed. It can be worse still if you have not got the O2 sensor
I said nothing of it increasing backpressure or exhaust flow, only that it can help to optimize fueling which, in turn, leads to smoother power delivery and a slight increase in hp/tq numbers (if done correctly).
Btw Alaska, I love those rear sets!!!! Are those stock? I don't assume they are, but haven't paid much attention to be honest.. just caught my eye when I was reading through this the first time and I forgot to say something. Looks like the Honda flying wing... awesome!
Discussion Starter · #17 ·
I'm almost never in higher revs where the yosh exhaust could do some good. But I bought the bike with the exhaust on it. Stock exhausts don't bother me except for the sound quality... I much prefer the slip-on.
1 - 17 of 17 Posts
