1 - 10 of 10 Posts
· Premium Member
That's oil.
Have you done a compression test?
· Premium Member
assuming the fuel is petrol and there is no diesel in there it may be your rings or the valve seals are shot.
comp test for the rings first as there the biggest job.
if that's ok you need to take the head off
That's a very good point :)
Any chance somebody might've put oil or deisel in your tank?
How much oil are you using?
You are checking the oil level with the bike vertical right?
· Premium Member
I just bought it off a noob who may have put way too much oil in it. ill check the levels, i hadnt done that yet :S
If the oil is very over-filled it'll get blown into the airbox and then combusted so check the airbox if it is too full.
· Premium Member
yeah i did check the airbox and.... IT WAS FULL OF OIL! haha i thought that was strange :S
hahaha
And yet it didn't occur to you that all that grey smoke might be burning oil?
1 - 10 of 10 Posts
