Hello! i made a video of my cbr 929rr, bolt snapped while tightening the bolt on my stator cover, how do i extract this little thing out? heres the video link
Need help how to get this thing out so i can return the bad stator to rick's.
thank you!
stator cover bolt snapped - YouTube
thank you!
Take the cover off and then remove the remains of the bolt.
Discussion Starter · #3 ·
thanks for your reply, but the bolt snapped inside of it, i mean, i know how to remove the other bolts, beside the snapped one
If it broke off then clearly it is not holding the cover on?
Remove the cover first and then you can address removing the bolt.
If you broke it because you over-torqued it then it won't even be tight.
If it broke because it bottomed in the hole then you will probably have to drill it out.
use easy out drill bit. drill a hole for the easy out bit to fit and screw it out just make sure you keep it as center as possible when trying to screw it out or you will break the bit goodluck. but what bladeracer said why cant you do that?
