1 - 2 of 2 Posts
So I cannot get my high or low beams to come on with my bi-xenon kit. The angel eyes and demon eyes power up fine so my grounds to my ballast must be good right? Each ballast had its own ground I just wired into the low beam - . My kit came with a H/L relay harness which I thought I had figured out, but I am guessing that is the problem. I attached a diagram of how I hooked it up, it might be tough to read. There were 4 wires (2 pairs) coming from the relay. I put one to high beam + and the other to low beam -, then the other pair I wired low beam + and -. My diagram shows a switch, but I removed that for not trying to solve the problem.
Any help is appreciated.
UPDATE: Figured it out. On the first wiring harness coming off the back of the bike
white= low beam +
brown= high +
Blue= low -
That top ground is wired to low beam negative, dont mind the schematic
Re: HIDS wont come on, but angel/demon eyes work
Also I am only using one plug for the high positive, not using high negative at all. Do I need to wire both high beam plugs together, I figured leaving one disconnected did not matter since I just need the signal to the harness.
Right click my image, open image in new window so you can zoom
Where did you get the Angel/Demon eyes? :idunno:
1 - 2 of 2 Posts
